2001 S60 cranks but doesnt want to start (hesitates?)
Old Feb 21, 2024 | 03:56 PM
Rait.V's Avatar
Default 2001 S60 cranks but doesnt want to start (hesitates?)
Hi, im having a issue with my 01 s60 that just doesnt want to start. It ran fine couple of weeks ago but now it just cranks but hesitates to start, even tried with some starter fluid and got nothing. When i started diagnosting i found that i had around 11 psi of fuel pressure in the fuel rail, changed to filter nothing changed, changed the pump and kaboom we have fuel pressure again (around 47psi after priming) but still doesnt want to start. Tested the spark plugs and coils but they were all fine, changed the spark plugs because they were pretty dirty and old already which i had to change anyway. Compression test was a success aswell nothing wrong with that. Connected my scan tool and got nothing, went over every single one of the fuses and relays but they were all fine aswell.
Pretty sure it cant be the crank/camshaft pos. sensor cause the rpm gauge responds when cranking so it feels like im running in circles at this point.
Added a video what my situation looks like while cranking. im having a issue with my 01 s60 that just doesnt want to start. It ran fine couple of weeks ago but now it just cranks but hesitates to start, even tried with some starter fluid and got nothing. When i started diagnosting i found that i had around 11 psi of fuel pressure in the fuel rail, changed to filter nothing changed, changed the pump and kaboom we have fuel pressure again (around 47psi after priming) but still doesnt want to start. Tested the spark plugs and coils but they were all fine, changed the spark plugs because they were pretty dirty and old already which i had to change anyway. Compression test was a success aswell nothing wrong with that. Connected my scan tool and got nothing, went over every single one of the fuses and relays but they were all fine aswell.
Added a video what "my" situation looks like while cranking. (This video is not mine but i got permission to use it, my situation is pretty much exactly the same as shown in the video.)
mooses9
Jan 10, 2016 07:15 PM
one320fc
May 24, 2013 10:05 PM
myanny
Oct 12, 2009 12:21 PM
thompson07
Aug 9, 2009 10:57 AM
turbo940
Mar 29, 2008 07:18 PM
