2001 S60 Water pump removal
Old Feb 18, 2019 | 08:41 PM
tschrock's Avatar
Default 2001 S60 Water pump removal
Hi all,
My son and I are trying to replace the timing belt on his 2001 S60 T5, which I believe is the 2.3L engine. Right now, we have everything off except for the water pump and cannot get that bugger off. Just a bit of the seal cracked on the bottom, but it still won't budge. What are we missing? Any thoughts?
There is a bit of a plug or something between two bolts. The new pump has a thru hole that is smaller than the bolt holes leading us to believe maybe there's a guide pin? I took a pic and circled what I believe is the "offending" item. How do I get this off?
Old Feb 19, 2019 | 07:29 AM
ES6T's Avatar
Once the bolts are removed, you should be able to pry it off. It might just be hanging up on the dowels.
lcocke
2001-2013 model year V70
Jun 26, 2015 08:54 AM
jigen3
Apr 17, 2013 11:34 PM
HECTORPORTALUPPI
Feb 18, 2012 09:00 PM
zero324
Oct 29, 2010 10:42 AM
joggieroets
Aug 26, 2010 06:19 PM
