1994 volvo 940 coolant leaking from the front of water pump
Old Feb 8, 2012 | 06:21 PM
HECTORPORTALUPPI's Avatar
Unhappy 1994 volvo 940 coolant leaking from the front of water pump
Hi!
My 1994 volvo 940, california car , gasoline engine, is leaking from the front of the water pump.
Tomorrow, i will loose the power steering PUMP, and remove the puley in front of the engine so it will expose the water pump and i really see where it is leaking from.
It seems like the water pump gasked!
Does any body knows how to remove and replace the water pump?
There is a red pipe that goes from the water pump to the back of the engine.
How do i deal with it?
Thank you.
Hector.
Old Feb 8, 2012 | 07:49 PM
NCVOLVO940's Avatar
hector,
do a search on the forum, there's a couple good write ups done, that go into pretty good detail. the red pipe bolts to the water pump, and will have to be unbolted before taking the pump off the block.
good luck with the repair, you shouldn't have any problems doing it.
Old Feb 9, 2012 | 02:41 PM
lev's Avatar
lev
No need to loosen the PS... I just undo the 4 bolts in front of the water pump, and pull the pulley straight out. Use 6 point socket, those things are SOFT. Then take out the timing belt cover, there is the pump! All 10mm bolts, a couple of nuts... The red pipe to the back is 10mm bolt with a nut on the back. Installing it make sure you cinch up the pump upwards to line the holes as the new gasket that seals it to the head needs to be compressed a little... Some use a jack to push it up...
Old Feb 10, 2012 | 01:56 PM
People, do understand that a leaking water pump is the BEGINNING of the end of the pump. The pump can leak for months before you replace it. I had a pump leaking on my 740 for about 6 months (20,000 miles) before I replaced it. If the leak is significant, do replace it ASAP, but if it's only leaking a few drops at a time, don't get to much in a hurry.
Volvo techs actually have leak limits.
Old Feb 18, 2012 | 12:10 AM
Hi!
This is hector.
The pump was leaking from the upper round gasked (ruber).
I replaced the water pump and all the gaskeds.
Thank you all for the help.
Hector.
Old Feb 18, 2012 | 10:41 AM
ed7's Avatar
ed7
The top gasket is a common leak point. Hopefully you cleaned the sealing surface on the engine. Loosen all bolts slightly and lever the pump upward to compress that top seal.
No need to drain the system again.
Ed
Old Feb 18, 2012 | 09:00 PM
Thank you ed!
Everyting works fine. No leaks!
Problem solved!
Hector.
Dtheswan
May 29, 2015 10:40 AM
92_240_sedan
Jun 26, 2013 06:57 PM
laurawoc
Sep 14, 2010 01:31 PM
firepop5
Aug 5, 2010 10:24 PM
jlb1181
Apr 8, 2010 08:35 PM
