The 2002 S60 90,000 mile dealer checkup
Besides the owners manual is there someplace/somehwhere I can see a detailed checklist of what a dealer does to the 2002 S60 during the 90,000 checkup? A document download or another site perhaps? Thanks, Ralph
Adjust Parking Brake System
Check Brake Pad
Inspect
Automatic Transmission/Transaxle
Check automatic transmission fluid level only if an external leak is identified.
Battery
Brake Fluid
Brake Hose/Line
Check for damage / leaks.
Constant Velocity Joint Boot
Coolant
Check / adjust.
Drive Axles, Bearings and Joints
Check Boots, Check Joints for Wear/Play
Drive/Propeller Shaft
Exhaust System
Check for Damage/Leaks
Fuel Supply Line
Check Fuel Lines for damage/leaks
Power Steering Fluid
Check/Adjust Fluid Level
Steering and Suspension
Check for wear.
Tires
Check pressure, wear and condition.
Transfer Case
Bevel gear, visual inspection.
Washer Fluid
Wiper Blade
Replace
Cabin Air Filter
Recommended to replace more often in heavy traffic and or dirt / dusty areas.
Engine Oil (E)
Oil Filter, Engine (E)
Reset
Service Reminder Indicators
Check Brake Pad
Inspect
Battery
Brake Fluid
Brake Hose/Line
Coolant
Check / adjust.
Exhaust System
Fuel Supply Line
Check for wear.
Tires
Transfer Case
Washer Fluid
Wiper Blade
Replace
Cabin Air Filter
Engine Oil (E)
Reset
Wow, that's excellent J.A., just what I was looking for. Trying to think of alternatives to an expensive trip to the dealership while maintaining my newly acquired S60. Is the Reset of the Service Reminders something my regular mechanic can do? Are the tolerances/values used in the Check/Adjustment section of your list available anywhere?
The service reminder message can be done by just about anyone.
Resetting the service reminder indicator (SRI), model years 2002-
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The text message is displayed for 120 s each time the ignition is switched on.
Proceed as follows to reset the service reminder indicator (SRI):
-Ignition position I
-Press and hold in the reset button for the trip odometer
-Ignition position II.
Note! Turn the key to position II within 2 seconds.
-Hold the reset button for the trip meter pressed in until the original value has been reset.
Note! For all vehicles from the 2003 model year a general yellow lamp will light when the reset button must be released.
-Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded
-If the trip meter is already reset the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds.
Note! If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset.
Most of check/adjustment is visual.
Brake Lining (Disc)
Good: over 5mm or 7/32" for discs.
Monitor: 3-5mm or 4/32" to 7/32"
Replace: Less than 3mm or 4/32"
Torque Specifications:
Automatic drain plug: to 35 Nm or 26 ft lb
Auxiliary drivebelt tensioner: 20 Nm or 15 ft lb
Engine oil drain plug: 35Nm or 26 ft lb
Engine oil filter housing: 25 Nm or 18 ft lb
Wheels: 140 Nm or 103 ft lb
Spark plugs: 30 Nm or 22 ft lb.
Brake Lining (Disc)
climbca
Feb 24, 2013 02:03 AM
trailfan
Sep 1, 2009 02:27 PM
