2002 S60 shakes too much to drive.....
During acceleration the car shakes as though a tire was falling off. Bad if done under 50mph, downright scary above 50mph. Lug nuts are tight, no obvious rim or tire damage, no leaks noticed.
I would like to arrive at the dealer with some thoughts - kept to myself of course; not impressed with the local dealer and cannot drive ot 50 miles to another dealer.
I would appreciate some "possible" causes. Oh yes, when the violent shaking starts all I do is let off the gas and the shaking totally stops!!!
You might as well check your engine mounts.
Even slightly loose or with a worn silent block, these things can give rather impressive symptoms.
I also have a LR Freelander which was clunking and shaking hard due to an engine mount gone bad. Stealer couldn't figure it out.
I did
... but after 6 months ![Stick Out Tongue](https://volvoforums.com/forum/images/smilies/tongue.gif)
If, however, the vibration travels through the steering, double check the wheels balancing also.
Good luck.
I did
![Big Grin](https://volvoforums.com/forum/images/smilies/biggrin.gif)
Good luck.
I also have similiar symptoms on my 04 60R. The difference is that even when I let off the gas the vibration will still be there, though it it worse when under load.
I have replaced both front wheel bearings and front drivseshafts, as well as motor mounts. Many of the annoying noises have disappeared, but this one remains.
0-40 I only feel a vibration under heavy acceleration
40-50 it picks up
60-75 gets really bad
over 80 - still there but not as noticeable.
It seem as if the problem is coming from somewhere in the rear, but I can't be sure. Engine seems to strain more than necessary under acceleration (sounds labored more than it used to)
Also have put new tires on and had balancing verified multiple times.
Getting frustrated.
40-50 it picks up
Getting frustrated.
Steady
08-08-2008 11:11 PM
