2002 S60 shaking getting worse...............
Old Jun 16, 2012 | 07:20 AM
jimduke's Avatar
Default 2002 S60 shaking getting worse...............
Please give me your thoughts.
Steering wheel shakes from about 10-55mph and gets much better after 55. Taken to a dealer in Huntsville and in Memphis - neither can find anything wrong.
Tires have been checked for damage and they have been balanced - by both dealers. They tell me that all suspension parts check-out normal. I think they gave it a good shot to find the problem - no repairs equals no money for them.
Here is what I am thinking: some part has a slight bend that is not readily obvious to the eye but is obvious under stress. What could be "bad" but gets better with speed?
I am close to parking the vehicle for fear that whatever is "bad" may fall apart at 60mph and kill someone!!
Any thoughts would be appreciated as the dealers have none.
Last edited by jimduke; Jun 16, 2012 at 07:24 AM. Reason: I forgot to mention that the problem is MUCH worse with 2 people in the car than with just me.
Old Jun 16, 2012 | 08:06 AM
Rotate the tires and report back.
Old Jun 21, 2012 | 08:17 PM
jimduke's Avatar
Changed front to rear today and the shaking stopped. An "out of round" rim?
Remember that the tires were balanced last week. How can I determine which rim is bad?
Thanks for all your thoughts.........
Jim
Old Jun 22, 2012 | 06:44 AM
Firedog's Avatar
I would think an out of round rim would be visible while on the balancer. Does your shop use the type with the cover? If so maybe they could spin it back up and see if anything's obvious.
Old Jun 23, 2012 | 12:13 PM
Nichals's Avatar
if your rim is out of round then you might very well have some other issues such as alignment, get the car aligned, buy a new rim. ask them to check all of them. you can also do it simply by jacking up the car in neutral and spinning the wheel
commodoreswab
Oct 24, 2014 05:48 AM
Volvo_n00b
Feb 26, 2011 01:08 PM
ibified
Jan 29, 2011 01:20 PM
jdarlin1
Nov 7, 2008 11:50 AM
bullit850T
Jan 29, 2006 01:14 PM
