2002 s60 tb problems I'm replacing the wiring harness also anyone done that before ?
Old Dec 30, 2023 | 11:33 AM
turbotim23's Avatar
Default 2002 s60 tb problems I'm replacing the wiring harness also anyone done that before ?
Hi my 2002 2.4 s60 had problem where the codes said throttle body[bosch] stuck open. I pulled the throttle body and cleaned it. My searching said the Bosch tb rarely goes bad but that the wiring harness does often go bad. From looking at the tb and testing it with a ohm meter, I'm pretty sure mine is good. I'm going to put the cleaned tb back on with a new hareness . Is the harness just a replacement harness or is it updated special one made to fix the problem? I bought the wiring plug to the tb side but I've heard that the harness goes bad at the computer, side I think the harness pins lose contact. Is that true? It's time to finally get this fixed anyone got any advice. Thanks
amirali73210@gmail.com
Oct 10, 2023 08:59 PM
87 740 turbo wagon
Jun 29, 2014 12:02 PM
firebirdparts
Jun 14, 2014 11:34 PM
rpc12
Jan 12, 2006 06:05 AM
AmishRebel
Jun 14, 2005 10:02 PM
