2002 S60 Trunk Release Malfunction
Old Dec 10, 2007 | 11:45 AM
kperveiler's Avatar
Default 2002 S60 Trunk Release Malfunction
The trunk release in my 2002 S60 suddenly stopped working from the remote or the release switch on the trunk lid - need to open with key.
Fuses are OK. Weird thing is that if you manually pop the latch to the closed position, everything works fine if the trunk is open more than a few inches - close it almost all the way and it stops working.
Only things that might relate to problem is that some not so heavy boxes were being carried in the trunk when the problem started and the rear marker lights on the driver side just burned out and needed to be replaced - both fairly normal things.
Any ideas would be appreciated. Thanks.
Old Feb 1, 2008 | 08:59 PM
grand94jeep's Avatar
Default RE: 2002 S60 Trunk Release Malfunction
I have the same problem, except I have a notice on my dash that the "Trunk Lid Open"
My remote won't work, and the pressure switch stopped working a long time ago. Is there some type of ballast/motion switch somewhere that will cause this malfunction?
I can unlock the trunk with the key..but nothing else will work.
Old Feb 2, 2008 | 09:58 AM
I would have the codes for the REM (Rear electronic module)pulled.
Old Feb 2, 2008 | 11:09 AM
Does this have to be done at the dealer? Or, can I take to AutoZone/Advance? My Bro-in-law has an OBD-II scanner. Can I use this?
Thanks Tech for the quick response.
Old Feb 2, 2008 | 12:42 PM
Most Average scanners won't read anything like the REM.
Best thing to do is try to find a Volvo specilist shop in your area.
kasey0505
Mar 3, 2025 04:28 AM
ndvs60
Aug 17, 2023 09:19 AM
slant6forever
May 3, 2022 02:57 PM
ddgm03
Oct 12, 2011 07:43 PM
topdwn
Mar 25, 2008 07:19 PM
