2004 S60, no front parking lights
Old Feb 11, 2026 | 03:41 AM
tobywood13's Avatar
Default 2004 S60, no front parking lights
Hi all, my 2004 S60 has no front parking lights, just the rear ones. The lights don't come on with the switch in the second position, either with the ignition on or off. They also do not come on when I press the yellow button on the key fob. I'm not getting an error message on the dashboard to say a bulb is out, is there a common cause for this?
From my research people seem to suggest that a control module may be faulty, so any pointers on things to check would be greatly appreciated.
Old Feb 28, 2026 | 05:03 AM
dhsyu's Avatar
Hello, my 2004 S60 only has rear parking lights, not front ones. When the switch is in the second position, neither the ignition nor the lights turn on. They also do not come on when I press the yellow button on the key fob. There is no error message on the dashboard indicating that a bulb is out. Is there a common cause for this? According to my research, it appears that a control module or fuse may be defective. Any advice on what to check would be greatly appreciated. I appreciate it already!
snaptube vidmate
wooter
Apr 29, 2020 11:30 AM
klaphunk
Dec 16, 2010 07:30 AM
peterjax
Aug 25, 2010 12:08 AM
LeChasseur
Feb 26, 2009 01:52 PM
PAPPYBALL
Dec 31, 2006 08:51 PM
