2005 d5 crank no start
Old Jun 26, 2022 | 01:28 AM
dws60's Avatar
Default 2005 d5 crank no start
Hi
I drove my car for around half an hour stopped at the shops after returning from the shops the car now only cranks and doesn’t start up no codes and no eml after around 20 mins checking sensors and boost pipes it then decided to start up but has now come across the same issue of cranking but not starting
any ideas on what the cause could be thanks
also car ran and drove perfect when it did start
Old Jun 26, 2022 | 08:03 PM
ssicarman's Avatar
Sounds like a heat soak problem taking out a sensor until it cools down.
Biggest suspect for me would be the crank position sensor. Being a 2005 and not having done any research to find out for sure you likely/should have electronic injectors which need the crank sensor signal to fire.
Daru
Oct 24, 2021 12:09 AM
Eldenia Jeneke
Sep 16, 2019 07:19 AM
Eldenia Jeneke
Sep 15, 2019 04:31 AM
pug604
Dec 22, 2010 06:44 PM
Betchins
Nov 21, 2005 01:38 PM
