2005 S60 R - What should I look out for
Old Feb 12, 2011 | 03:07 PM
patrickb's Avatar
Default 2005 S60 R - What should I look out for
Hello.
I'm considering purchasing 2005 S60 R AWD with about 95,000 miles on it. What things should I look for or ask about? What maintenance items maybe coming due, due, or over due that I need to be aware of?
Thanks,
Patrick
Old Feb 12, 2011 | 07:03 PM
Mad Matt's Avatar
Timing belt is about due. Make sure the AWD still works before you buy, the angle, collar gears are known to go out. Make sure you get as much service history as you can. Read up on Swedespeed's R Forum about some of the other issues that is R specific.
Old Feb 13, 2011 | 08:00 AM
patrickb's Avatar
Thanks for the info and resource. I'll wander over to Swedespeed and check out the forum there.
Overall, is the S60 R a reliable car? I understand that it's used and that, as with all things that move, things break, but, in general, is this a steady, reliable car?
Patrick
Old Feb 15, 2011 | 10:05 AM
malaka's Avatar
Also join and check True Delta. Per that source, R models need more fixes than non R models. Of course, given 300 hp, part of the problem might be the drivers' right feet!
Volvos, like most Euro cars, aren't cheap to keep or cheap to fix. You won't confuse it with a Corolla, by way of example.
jethrobodean
Feb 16, 2013 07:50 PM
Sleeper
Sep 6, 2011 10:06 PM
reedfriendly
Oct 12, 2010 10:54 AM
NC S60
Aug 24, 2009 10:30 AM
777funk
Mar 17, 2009 01:54 PM
