2007 S60 2.5T Low Coolant Alert
Old Sep 15, 2021 | 10:20 AM
JSLong's Avatar
Default 2007 S60 2.5T Low Coolant Alert
So I replaced the radiator a few months ago and put in new coolant. After a few initial system burps, everything was working fine.
Recently, as the system pressurizes, the low coolant light comes on. When I stop the car, and remove the reservoir cap, the expansion tank fills up, like it's over pressurized.
I'm not losing coolant, none in oil, no drips, etc. Is this just an issue with the reservoir cap or a thermostat issue?
Thanks!
Old Oct 26, 2021 | 08:20 AM
JSLong's Avatar
Does anyone have any idea why this is happening
Old Oct 26, 2021 | 11:54 AM
it's possible when the car was driven low on coolant or overheated (I know it never did to your knowledge, but you probably replaced the radiator because it was leaking) the head gasket was damaged. Extreme pressure build up is a symptom of that. Borrow a head gasket leak detector kit from your local auto parts and check for HC in the cooling system.
Ekuva Jona
Mar 24, 2014 07:14 AM
rspi
Jun 24, 2012 04:04 PM
1996850turbo
May 4, 2011 08:11 PM
daddynate
Apr 27, 2011 10:15 AM
opie
Jun 24, 2010 02:41 PM
