2007 s60 AWD DP and Catback
Anyone know of a full 3" Downpipe and Catback for an 07 S60 2.5t AWD? It seems that trying to find a DP for just the 2.5 AWD is not looking good. I have seen ones for the FWD and then S60R and none stating for AWD only. It looks like evolve has a DP for the AWD and cat back for just an AWD, but if anyone has experience with this year and these mods I am looking for some info.
Could I getaway with a S60R DP and catback? Or will the mount points be different on the normal 2.5t AWD?
RE: 2007 s60 AWD DP and Catback
The Rs use a KKK turbo, and I think they have a different flange, so you might not be able to on the downpipe, but you should be able to use an R catback.
You could email IPD if they have one that will work in your setup.
If I were you, I would just get a 3in custom Turbo-back exhaust done at a local shop.
Most of the aftermarket turbo-backs, cost more than custom anyways.
Actually, most of the downpipes Ihave seen cost more than a whole custom exhaust.
Just get free flowing (straight through design) muffler or mufflers, and a high flow cat.
FWIW, Evolve's is actually 3.5", I think all the rest are 3.0". You can always go to a muffler shop for a custom job, but if money is not an issue,I suggestthe Evolve dp and advanced exhaust. I have it and it sounds amazing! Might want to call just to check it out first.
But to answer your question, I don't know for sure if the mounting points are the same.
