Exhaust??? Down pipe and cat back??? or just catback
Old Jun 9, 2011 | 09:11 PM
hayn5-0's Avatar
Default Exhaust??? Down pipe and cat back??? or just catback
Hey gang wanting to put some type of exhaust system on my S70 and wanted recommedations for catbacks and or down pipes. would down pipes really make that much of a difference? Looking for a nice deep tone.
again thanks for your help and opinions. Aloha!
Old Jun 10, 2011 | 05:26 AM
tony1963's Avatar
Leave the base system in tact and use a high flow muffler in the back.
Old Jun 10, 2011 | 07:16 PM
Carrots's Avatar
What Tony said if you're just looking for sound. If your car is a turbo, get a turbo- back system, the one from IPD is the best, but expensive. The OBX systems are okay, as well. They use larger diameter pipe and a high- flow muffler. Both include a pipe that you can, and should, replace with a high- flow cat. Exhaust alone on a turbo car is good for lowering restriction, but where it'll really help out is if you eventually get a tune for your ECU. If it's not a turbo, there's not a whole lot that can be done for performance.
Old Jun 10, 2011 | 09:25 PM
hayn5-0's Avatar
what about buying a aftermarket ECU? any recommendations?
Old Jun 10, 2011 | 09:36 PM
hayn5-0's Avatar
can I use a universal fit down pipe ( $60.00) and have the additional pipe welded onto that? I've used a universal down pipe on my integra and had my exhaust guy just weld the extended part going to the cat area. Wanted to run it to a high flow cat then back to an exhaust. I noticed like a baffle system at the mid point of the stock down pipe but didnt notice any sensors attached to it. Can I run a custom down pipe? Thanks guys
Old Jun 11, 2011 | 03:54 PM
Roboticloner's Avatar
Eurosport Eurosport Tuning: RICA ECU Upgrade 1994-1998 Volvo Turbo Models
Ipd Engine ECU Flash Tune Upgrade for Motronic 4 Turbo Models 1994-19
Viva 1998 S70 Software Upgrades - ViVA Performance
Eurosport: Eurosport Tuning: EuroSport Stainless Cat Back Sport Exhaust System - Turbo FWD Models has a cat-back system for $479.00. Then you can find out how much a custom downpipe will cost from your local muffler shop.
Hope I helped
Joflewbyu2
Aug 25, 2012 09:09 PM
bond007
Jun 13, 2011 03:45 PM
stevenro64
Apr 19, 2011 05:23 PM
zloetakoe
Feb 25, 2011 01:49 PM
colgate41
Apr 7, 2006 03:25 PM
