2008 2.5T engine shudder stuttering at high speed
2008 S60 2.5T, 163k miles
At highway speeds (roughly 60 mph), if I try to accelerate significantly the engine shudders/stutters/stumbles and I have to back off the gas. At one point, the check engine light flashed but then went away. The engine idles just fine and there is no check engine light on. My first try will be to clean the MAF. Then I may try to pull codes (even though there is no CEL on). I might also try replacing all spark plugs.
Any other suggestions/comments?
