2011 S60 Drivers side control panel not working.
Hi, I recently bought myself a used 2011 S60, and as the title suggests. My drivers side door control panel does not work anymore
The car has been great so far, but about a week ago the control panel suddenly stopped working when I tried to lower my drivers side window, which resulted in the window having a slight gap since it wont go either up or down. The drivers side windows do not work as mentioned, both front and rear. And the doors do not lock on the drivers side as well but they do lock on the passenger side. I can't adjust my mirrors either and there seems to be no power at all to my door, except that the speakers in the door still work?
When I checked the fuse box, the previous owner had put a 10amp fuse instead of the 20amp that was required. The 10amp fuse had blown so I replaced it with a 20amp one, but that didn't fix my problem. I also checked for any snapped wires in the wiring loom that goes from the body of the car and into the door, but again everything seemed to be fine.
Has anybody else had this issue and how did you fix it?
Any help is greatly appreciated!
spieman
09-09-2020 09:59 PM
