2012 S60 sound problem
Old Oct 16, 2013 | 02:34 AM
Cyril France-Jackson's Avatar
Default 2012 S60 sound problem
Often when I start the car, the radio having been left on, I loose all sound. I then have to turn off radio, restart car, turn on radio again. This can take several attempts.
Anyone know this problem?
Thanks
Old Oct 16, 2013 | 08:47 PM
bobolat's Avatar
Do you have a bluetooth device connecting to the vehicle? I have a phone that is paired and often when I start the car, it mutes the sound while it tries to connect to the phone.
Old Oct 18, 2013 | 02:02 AM
Yes to phone connecting to Bluetooth but that's not the problem as sound does not return until everything re-started.
The biggest problem for me is that I don't always realise that my proximity warning sound is off.
Old Oct 24, 2013 | 09:24 PM
ayoung01's Avatar
This may sound crazy but take both positive and negative cables off battery and touch together for 15 minutes. Then try radio again. Could also be a software issue
Old Aug 12, 2019 | 05:04 PM
allan meyer's Avatar
Default Volvo radio stops working
It seems that my radio has a problem. I will have the radio on then after 5-6 minutes it will stop and says that it is having problem pairing with my phone. If i have it paired with my phone and i am listening to pod casts it will cut out. I think the problem is with the radio but dealership said it might be with the screen (that doesn't make sense to me). Do i have to replace the radio? any other suggestions?
Old Mar 20, 2020 | 07:59 PM
Polestar's Avatar
Thanks
Hello fellow Volvo owners!
I know this is an old thread but....
I have the EXACT same issue on my 2014 s60, and the only way to get the sound back is by doing the EXACT same steps as you.
I wonder if you found a solution to this provblem?
Old Apr 25, 2020 | 03:07 PM
Rashka Manning Ross's Avatar
I am having the same issue and I've been told it's the IAM possibly failing
Old Sep 30, 2021 | 10:57 AM
Jarrod's Avatar
Default Sound issue
Hi guys,I'm having the same issue,the radio can be working fine,I get out the car,lock up and when I come back the screen will be on but no sound,I have to switch off,open driver door to knock it off and then restart,then the sound is back!
Anyone have any idea what the problem could be,answers much appreciated???
Old Jan 16, 2022 | 06:16 PM
amsharifian's Avatar
Same issue with S60 2012. I'm not sure if there's a relation but I'm in Vancouver and this happened to me a couple of times once we had heavy rain.
I'm curious to find out the reason
Angel583
Sep 4, 2016 07:57 AM
LittleMushi
Mar 8, 2016 02:52 PM
Jules89
Dec 16, 2013 02:36 PM
PeterS
Dec 1, 2004 06:12 PM
