2012 Volvo S60 T5 Misfire Problems
I have a 2012 Volvo S60 T5 , Getting 3 codes P0300, P0305 & p0304, the issue seems to be with cylinder no. 4. I have already swapped coil pack and the issue seems to stay with cylinder 4 & five. We just changed all spark plugs with new ones. Interestingly, autozone has 4 brands with different spark gaps. What is correct gap for this vehicle? All the injectors read at 14.4+ ohms, so i think these should be ok!
Question, What kind of computer and where is this located that controls coil packs input voltage & firing order? What else do i check for. Car still runs but definite misfire.
Thanks friends
Art G.
Thanks friends
Art G.
Thank you for your help & Yes, we did return coil packs to their original position. Cylinder no.4 is a little wet from gas though, at least it appears so. Do you know where the computer control module is located at that controls the electronic spark for this Vehicle, 2012 Volvo S60 T5. How do I know for sure if i have a Turbo? Also, where is good after market place to purchase parts for this import.
Art G.
Art G.
divinedavis
02-28-2016 06:33 PM
brent@fluidequipment.com
08-17-2014 12:32 PM
