2013 s60 trunk unlocking all locks
Old Aug 8, 2025 | 09:26 AM
Eric Hilton's Avatar
Unhappy 2013 s60 trunk unlocking all locks
I can lock the car with the fob, switch on the door and switch on the trunk lid. All the doors will lock. The trunk will lock. I can unlock the car doors with two taps on the fob. I can unlock the trunk using the fob. If I use the unlock switch above the license plate it unlocks the trunk and also unlocks the doors. So no matter how I lock the car up, everything opens by a press on the switch above the license plate. Any suggestions?
Old Aug 24, 2025 | 02:23 AM
dhsyu's Avatar
I use to use this method all the time. I think because I had the valet lock on. Then someone showed me there is a soft button under that same area. If your car is unlocked, you can fidn the soft rubber with your fingers and there is a button that you push upwards.
Tutuapp 9Apps
Recharge
Oct 22, 2022 02:46 AM
tog244
Jul 31, 2021 09:00 AM
volvodriver99
Jun 24, 2020 06:20 PM
BSBERRY2
Sep 11, 2018 12:33 PM
stevied
Jul 2, 2007 03:08 PM
