2015 Volvo s60 t5 awd fuel filter location? Please help
Old Jun 9, 2020 | 10:13 AM
Cheb's Avatar
Default 2015 Volvo s60 t5 awd fuel filter location? Please help
I have spent hours underneath and around my volvo and I just can NOT find the fuel filter, and I'm pretty sure mine doesnt have the kind that's in the fuel tank. Any help will be much appreciated!
Old Jun 27, 2020 | 03:10 PM
Brian Winnie's Avatar
Did you ever end up finding it? I’m currently looking and can’t find mine.
Old Jun 27, 2020 | 04:09 PM
many models don't have an exterior fuel filter - it may be built into the pump inside the take. If you don't see the cannister then your car doesn't have a user serviceable filter.
Old Jun 27, 2020 | 05:39 PM
When I searched for the part by my vin it gave me a filter and it seems to be mounted externally. I removed the plastic guard under the passenger rear door area and could not see it. I am wondering if it would be easier to find with the car on the lift. The filter that came back as a result after searching the part using my vin had both the inlet and outlet on the same side.
Also, I will call the dealer on Monday to see if they can give me any insight.
Old Jun 28, 2020 | 10:52 AM
not sure about the 2015s but in prior years cars came with either a metal gas tank (California certified cars - had the internal filter) or a plastic tank. If you have a cannister, my guess is it will be ahead of the right rear wheel. You can try using a VIN decoder as well to see which plant built your car and see your serial number fits into the following:
wo/ External Fuel Filter; Torslanda Plant Built; From Chassis/ VIN 391007
Old Jun 28, 2020 | 10:59 AM
Mine was manufactured in Ghent and the tank looks plastic.
I guess I will just have to get it on a lift so I can get a better look.
Old Jun 29, 2020 | 02:51 PM
or call a dealer / volvo friendly parts store and give them your VIN :-)
Old Jun 29, 2020 | 03:17 PM
I will probably call this week. They were closed Saturday by the time I was able to call.
nathan777
Jul 23, 2023 06:38 PM
Cuazi Modo
May 5, 2017 09:55 AM
Darren Reinke
Sep 28, 2016 09:54 PM
Delirious
Mar 31, 2009 08:48 PM
matthiasfan
Jan 24, 2008 05:51 PM
