2016 S60 Overheating
Old Oct 1, 2025 | 12:47 PM
joemahoney79's Avatar
Default 2016 S60 Overheating
I am chasing an overheating issues with my teenage son's Volvo S60.
The car developed a coolant leak because the small plastic crossover coolant tube cracked. I drained the system, replaced the tube, and vaccum filled the cooling system with a 50/50 mix of Volvo coolant and distilled water.
Following the repair the vehicle overheated on the test drive. There was no heat coming from the heating system. Then right before I pulled over for a tow, the heat started blasting in the cabin and the vehicle temp came back to normal. Assumed it was an air pocket. Waited overnight for the car to cool and expected I would need to add some coolant to the reservoir becuase of the vacated air but the level was fine.
Since then I have taken 3 more short test drives. All of which had a high temp episode with a loss of cabin heat only to have everythign go right back to normal. Once normal I can let the car idle at home. The radiator is rejecting good heat and the fan speed is modulating.
The only item of note from the repair is that I could not get any drainage from the lower petcock on the radiator drain.
Almost seems like the thermostat is sticking but I wouldn't think that woudl impact the heater core for the cabin??
Any help woudl be apprechiated
jcb139g
2001-2013 model year V70
May 25, 2018 09:54 AM
zippinbye
Jan 27, 2013 12:01 PM
feisty_bee
Feb 6, 2009 10:05 AM
gooproduct
May 9, 2007 12:18 AM
my850turbo
Jul 22, 2006 12:52 AM
