ABS Lights
ABS Lights
2001 S60. ABS and TRS lights come on intermittently. ABS brakes will kick in every once in a while and activate the pedal durring regular braking. Seems to do this only when the ABS/TRS lights are off. Replaced the ABS control module w/ a remanufactured unit from BBA and it has had no effect. The check engine light is also on. It shows 2 trouble codes, both of them are PO500 (Veh Speed Sensor A malfunction). Any one have any ideas what the problem is?
