ABS wiring location
2002 non turbo S60 with the dreaded ABS alarm
DTC #1A5F had the module sent to Xemodex for repair/evaluation
Module is good, still have ABS warning message, checked all normal things battery voltage, brake position sensor, power at module is good.
Canbus wiring between CEM, ECM and ABS suspect, looking for the location of connections 53/430 and 53/431
Would think they would be under the dash located between CEM and firewall but I can't find them, any help would be greatly appreciated.
Thanks
Thanks
