Aim / adjust headlight beam - when it is required.
Old Mar 29, 2009 | 05:18 PM
Jimbo_Jones's Avatar
Default Aim / adjust headlight beam - when it is required.
When replacing high beams or low beams, is adjusting the aim of the beam normally required? Or, if the aim of the beam was OK before you replace the bulb, is it normally OK *after* replacing the bulb?
Thanks in advance for any replies.
Old Mar 29, 2009 | 07:12 PM
You should not need to adjust after replacing the bulb.
MRS60
Sep 17, 2013 09:20 PM
borimrr
Jul 19, 2013 08:31 AM
pezwack
Nov 7, 2011 05:42 PM
Volvoguy505
Sep 11, 2010 05:53 PM
