Alignment issues- tire wear
SO i put new tires on the S60 last summer. I had the wheels aligned as well. I noticed the rear suspension has some camber to it...I had asked the shop to give me ZERO camber in the back. I'm not as concerned about ultimate cornering as i am about tire wear....so they said it wasn't adjustable in the back..Great ! now my rear tires look like crap already on the inside edge....anyone else have this issue? Do i need to "customize" my rear control arms? Thanks
I usually set the toe closer to equal (that right rear is in spec, but could be better).
Otherwise, the alignment is fine. You may have some worn shocks. I've also seen a couple instances where the bushing where the toe adjustment bolt passes through breaks and causes play.
What kind of tires are they?
These are cooper Zeon RS3's....their not 60, 000 mile tires...but they should be this goofed up from one summer season. I take them off in the winter and put on snows....I'll check for free play under there....I'll also check to see if there's a way to get these wheel straight up and down! this is no track car! I've already got one of them..
well look what i found. A set of adjustable camber bushings from IPD...My plan is to adjust my rear wheels with ZERO camber. maybe i'll get some life out of them. stay tuned.
Volvo Rear Camber Bushing Kit IPD 112394 30748889P, 30748889, 8K0154, 9200154
C-70 tire wear
I have a 2009 c-70 and since my wife hit a curb, I have a serious issue with this car eating tires from inside. I had to replace the support arms, and have been told these sport tires are only good for about 20k. Pilot tires are very expensive. Can I put a cheaper tire on this thing?
