Another Oil Leak
Old Feb 10, 2007 | 02:13 PM
MK1's Avatar
MK1
Default Another Oil Leak
Any idea about this oil leak? It seems to be a pretty good one this time. This picture is looking down towards the bottom of the belt, just above the axle...I think.(I hope this picture loads) Our '01 has abouto 103K on it. I'm going to try to get in it Tuesday, but was wondering if anyone has any input. Thanks for your help...this board is awesome!
[IMG]local://upfiles/2614/E993ABC50BE84FE39860C8F19A1093D7.jpg[/IMG]
Old Feb 10, 2007 | 04:58 PM
Default RE: Another Oil Leak
Looks like it might be the Cam seals leaking.
If you can remove the top cover of the timing belt 2 T-30 screws.
See if it is wet under the cover.
Old Feb 10, 2007 | 06:27 PM
MK1's Avatar
MK1
Yes, there does appear to be fresh oil residue under the timing belt cover. Any ideas on how big a job it is to get the cam seals done if that is what it is? I always like to have an idea of what I'm in for beforeI take it in! Thanks again for your help!
Old Feb 10, 2007 | 06:50 PM
The cam seals are a pain.
The car has VVT (Varible Valve Timing)
If that seal is leaking there is an entire way you need to go through to set it all back up.
If the timing belt is wet with oil that should be done as well.
I would say hopefully max 5 hours labor.
Old Feb 10, 2007 | 06:59 PM
MK1's Avatar
MK1
Thanks!
Old Feb 10, 2007 | 07:04 PM
Your welcome.
At work I am considered the VVT specialists!! LOL
Old Feb 11, 2007 | 07:34 PM
MK1's Avatar
MK1
I just got to thinking...I'm not looking at another $800 timing belt job am I?? That would not be good!
Old Feb 11, 2007 | 09:27 PM
Sorry to say but yes.
Old Feb 11, 2007 | 09:33 PM
MK1's Avatar
MK1
Being a Volvo owner doesn't come cheap!
Old Feb 11, 2007 | 09:54 PM
No it doesn't.
Old Feb 12, 2007 | 08:57 PM
MK1's Avatar
MK1
Ok, Ok...here is the final verdict: Bad cam seal (good call tech) and bad crank case seal. I'm out about 200 bucks this time around. It's good to have a decent independant mechanic.
Old Feb 12, 2007 | 09:47 PM
Cool glad it wasn't to bad on you.
shelley71
Nov 13, 2011 09:32 PM
Hi555
Jul 13, 2011 06:39 AM
Adrenalin540
Dec 15, 2008 03:37 PM
Wreck 75
Jan 19, 2008 03:58 PM
92Typhoon
Nov 22, 2005 01:01 AM
