awd prop shaft (rear drive shaft) removal
Old Dec 5, 2022 | 10:22 PM
  #21
imacoolnavyvet's Avatar
Default Solution
Originally Posted by s60propshaft
So, i struggoed with this for EVER. and - much to my dismay - swear words did not make it come out. I did, however, discover a pretty good way to do it.
Make sure you have enough room to swing a hammer and see well
Look at the back of the flange... see the holes? see some holes match up with the threaded holes on the front and some don't? take a allen wrench and stick it in one of those holes until you find one that it 'bottoms out' in. Once you find it - take a 2" long crappy driver bit (not flat head - star bit or square worked best for me, but ii doesn't matter)
Stick it in that hole until it bottoms out.
get a 1/4 inch socket that will fit around that 2" driver end that is sticking out of that hole. (6.5mm or 7mm i think)
Take a 6"-9" long 1/4 inch extension and line it up with that socket the best you can and then hit the crap out of that with a hammer. It will drive the cv join out of the flange.
Old Dec 5, 2022 | 10:31 PM
  #22
Default Prop Shaft Rear Removal
Old Jan 15, 2023 | 06:59 PM
  #23
lunabulldog's Avatar
I will try your method and let you know. At least now I know where and how to hit it for it to come out and hopefully not hurt anything
benpineapple
May 13, 2015 08:59 AM
rip7443
Dec 12, 2010 06:31 AM
rolling2
Sep 25, 2010 12:59 AM
carpcatcher
May 7, 2009 02:05 PM
pbruin
Engine & Internal
Aug 8, 2005 10:03 PM
