Bevel Gear Oil loss
Noob here, but I've read what I can on this subject.
My 05 S60 T5 has 65k on it. In the past 10k or so I noticed the bevel gear housing was wet.
Some careful measuring found I was 7oz low. Thing is the input and output shafts are not leaking. So I guess its only leaking from the housing surfaces themselves?
At 65k is it worth pulling the unit for a reseal? Do I deal with the slow leak and top off?
If I do a reseal can I just reseal the housing with some anaerobic sealer and be done with it?
From my research if I am going to pull it I should replace the shaft seals, use anaerobic sealer on the housing, drill out for a drain and replace some input splined shaft as these seem to fail and cause the bevel gears to fail.
Advice welcome here. I understand what is involved, but not sure the best course of action. I'll be doing all the work myself. Just seems silly to pay over a grand for a dealer to reseal a housing and out it back in.
76 Capri 2.3 Turbo
76 Capri II 2.3 Stock
67 MG Midget
05 Volvo S60 T5 AWD
76 Capri 2.3 Turbo
67 MG Midget
05 Volvo S60 T5 AWD
carlheat
10-25-2010 10:36 AM
