bevel gear leak
Old Oct 20, 2006 | 07:57 PM
jhaw's Avatar
Default bevel gear leak
The output shaft seal on the bevel gear assembly on our 99 XC was leaking and the dealer installed a new seal. The new seal still leaks. Is it possible that there is a pressure build up in the case causing the seal to leak. If so, what would cause the build up?
If there is a bevel gear failure, could I just unhook the driveshaft?
Any responces would be greatly appreciated.
Old Oct 20, 2006 | 10:38 PM
Ihatespeedbumps's Avatar
Default RE: bevel gear leak
It's very possible they didn't clean the bevel gear after the repair. I'm not sure wh you mention removing the driveshaft. If you did that the car wouldn't go anywhere! If your concerned the repair wasn't done correctly, it's best to take it back to the dealer.
Psaboic
Sep 20, 2022 02:30 PM
carlheat
Oct 25, 2010 10:36 AM
rmmagow
Sep 23, 2010 01:56 AM
ryan314
Jul 14, 2007 06:03 PM
Volvo V70R
May 9, 2007 09:15 AM
