Both low beams getting no power.
Old Jan 22, 2014 | 07:55 PM
mechanicboy's Avatar
Default Both low beams getting no power.
I recently converter my 04 s60 from HIDs back to factory style bulbs. They worked great for about a week then suddenly they both stopped working. I did a search and found out this is a semi common issue. I followed all the diagnostics that I could but now I'm stumped.
Here's what I've found:
1. Tested Both lowbeams and they are good.
2. No power to both lowbeams at the bulbs.
3. No power to fuses (not blown) in the engine compartment for the low beams expect the left one seems to have so residual power somehow, just a few volts.
4. There good power to the fuse (not blown) on the left side of the dash.
5. Swapped relays for the lowbeams on the board under the dash, nothing changes.
6. Swapped the low beam shunt, still nothing.
I'm at a loss right now, and help would be appreciated as I need to get the car inspected and it will fail the light inspection (yes, they actually check them here).
Thanks.
Old Jan 26, 2014 | 01:06 PM
I guess I ask the hard questions.
Old Mar 25, 2014 | 02:23 PM
billnet8's Avatar
What did you do about your low beam problem before inspection? Having similar problem. Would appreciate advice. Thanks,
bill
98isb360
Oct 13, 2021 08:47 AM
bkhan145
Mar 16, 2019 02:22 PM
RJSV70
2001-2013 model year V70
Feb 23, 2014 10:34 AM
elderzap
Nov 7, 2007 04:58 PM
spinningcain
Jan 25, 2006 09:02 PM
