Brake Light
Old Feb 12, 2007 | 01:32 PM
mistralt5's Avatar
Default Brake Light
Hopefully someone in the forum can help me here. I have a 2001 S60 T5 and have noticed that the brake lights are illuminating whenever I press the clutch to change gear. It's not a big issue, but annoying. Can anyone suggesta potential fix or adjustment?
Thanks.
Old Feb 12, 2007 | 09:18 PM
Default RE: Brake Light
Check the wiring leading to the switch. Make sure the clutch pedal isn't pulling the wires to the switch.
Also try adjusting the brake light switch.
Old Feb 13, 2007 | 05:06 AM
mistralt5's Avatar
Thanks for the help. Is the switch accessible and wiring loom accessible? Cheers.
Old Feb 17, 2007 | 12:53 AM
You can get to it once you remove the black lower dash panel.
Old Feb 19, 2007 | 05:07 AM
mistralt5's Avatar
Thanks Tech,
Really appreciate your help.
nealeas
Mar 24, 2018 09:59 AM
glixons
Jan 4, 2015 06:15 PM
zinko
2001-2013 model year V70
Feb 11, 2014 07:18 AM
MaZoN
Aug 5, 2008 06:52 PM
mywifescar
Jan 13, 2006 12:59 PM
