Cel- code p0299/p0193
Old Jun 30, 2009 | 10:33 PM
walter351_'s Avatar
Default Cel- code p0299/p0193
I own a 2004 S60 2.5T, Vehicle has 66,000 miles on it. I decided to have the spark plugs and timing belt/tensioner/idler changed as a precaution due to other posts that I have read.
I recieved the car back, started and drove it 4-5 times before the CEL came on. Took the vehicle to Auto Zone for a quick code pull and the following codes were identified:
-P0193
-P0299
I have read that the P0193 is most likely the fuel rail pressure sensor, but
I am up to any suggestions
The P0299 code is what bothers me the most. Low boost pressure code. Any suggestions would be great in resolving my problem.
Old Jul 3, 2009 | 08:00 AM
Make sure they did not knock any hoses loose while doing the work.
Old Jul 4, 2009 | 05:04 PM
redz1006's Avatar
I do not get CEL but every now and then when I check for DTCs
I see P0299 (low boost). I guess it did not occur often enough to cause
CEL.
What hoses do I check ? ALL the ones connected to the TCV
seems to be fine.
Is this a sign that CBV might be failing ?
Old Jul 5, 2009 | 11:02 AM
It is possible but I doubt it. I would also check the intercooler hoses.
matt01
Jul 23, 2012 11:12 AM
S80GAS
Nov 1, 2010 10:55 PM
apexnut
Feb 2, 2010 08:42 AM
screwdrag
Nov 7, 2007 10:52 PM
migkam
Sep 26, 2005 11:11 AM
