changing engine coolant
Old Nov 6, 2007 | 03:34 PM
thullz's Avatar
Default changing engine coolant
I have on 01 s60 and with the cold weather now I've noticed that the temp. gauge is one notch lower than where it has always been when the car is fully warm. Should I do a coolant change/flush? what type of coolant is best for this model?
Cheers
Old Nov 6, 2007 | 03:54 PM
jks2's Avatar
Default RE: changing engine coolant
Need more information on mileage. I would only do it if it looked discolored or you were at a mileage that Volvo suggested it be done.
Old Nov 6, 2007 | 06:48 PM
mncx's Avatar
there is no specific to when for coolant to be change. but anything it looks discoloured and chunks of mineral build up inside reservoir I would change it.
Old Nov 22, 2007 | 02:17 PM
thullz's Avatar
01 with 163K KM.
It's been running cold and taking longer to warm up. It was -5 the other day and the car took a while to warm up but then once I got on the highway it actually cooled down to about a 1/4 on the guage before gradually warming back up.
During the summer my guage is at 1/2 but it rarely gets there these days and we havent really hit subzero temps yet.
Should I change the thermostat and do a coolant flush?
Do I need to reset/disconnect the battery after a thermostat change?
Car runs fine otherwise....revs high for a 30-60sec on cold start but that comes down.
cheers
Old Nov 24, 2007 | 07:41 PM
Fisher's Avatar
The coolant should be changed the prevent corrosion. It generally would not affect the warmup.
The thermostat should be changed because it is stuck open. The car will be hard to warm up.
No need todisconnect the battery.
Old Nov 30, 2007 | 11:11 AM
thullz's Avatar
Changed the thermo, which took all of five minutes to do and did a drain and fill. Problem solved.
Joflewbyu2
Aug 17, 2012 05:53 PM
BenHur
Sep 24, 2011 06:39 AM
Ahmed
Aug 30, 2009 01:58 PM
aruizdelhoyo
Jan 22, 2009 04:46 PM
timk
Nov 16, 2007 08:33 PM
