Charge pipes
Old 08-24-2011 | 07:29 PM
08s60boost's Avatar
Default Charge pipes
So I just got done installing my 2 1/2in charge pipes, with a bov on my car looks real good best 200 bucks ive spent thus far!!!!
Old 08-25-2011 | 04:26 PM
MYS6T's Avatar
Bov not a great idea in these car. The car has a Compressor bypass valve that re-circulates the extra boost. With a BOV the extra is let go in to the Air.Now when the car calls for the extra boost pressure there is none. I use a Hiflow intake gives the same sound with out the negative impact on performance.This is just my thoughts form what i have read on the subject.
Old 08-25-2011 | 05:46 PM
08s60boost's Avatar
Im actually very impressed I did my research and decided to go ahead and do it! I dont notice any turbo lag I got a substantial mpg increase though. Now im looking for a exhaust system and 3in dp
Old 08-26-2011 | 04:47 PM
MYS6T's Avatar
for a 3inch down pipe OBX can not be beat. They are catless so if you want a cat one can be welded in but take a look at this thread with 100s of guys using it. Swedespeed Forums - Cheap OBX Exhaust
They also have an exhaust but it has a 2000rpm drone so if i were to do it again i would go with a custom look over at swedespeed.com you can find a few guys that have builtd great setups for 1/2 if not more than the Box set up from company's like EuroSportTuning,Viva performance cost. They are good setups but cost $700+
Old 08-28-2011 | 05:52 PM
08s60boost's Avatar
Thats what im seeing when I look around. Im contacting kteller piping and see if they can make me a kit. Can I up the boost any with a aftermarket controller? if so how much?
Old 08-28-2011 | 11:39 PM
pontingroy's Avatar
A vacuum tube that runs on a fuel injection system that directs air air pump to the input (bypass valve, BPV) or the atmosphere (exhaust valve, BOV) for the slowdown in high vacuum eliminate detonation.
Old 08-29-2011 | 04:04 PM
MYS6T's Avatar
The answer is no. The only way to up the boost and HP is threw an ECU tune $895.But well worth it.
mick1232
05-31-2009 12:23 PM
volvos70t5boy
03-25-2009 06:14 PM
LouisCas
12-30-2008 07:04 PM
otizzy
Intake, Headers and Exhaust
10-11-2007 11:22 PM
Rob`s60
07-25-2007 02:00 AM
