Check Engine Codes P0235/P0236 - MAP Sensor?
2001 2.4 Turbo S60.
Checj Engine Light on for about a week...todays IBD II check gave codes P0235 & P0236 with the Autozone explanation being several things including a bad MAP sensor....I can tell no change in performance....
How can I be sure it's the MAP sensor and not something else, short of spending money at a mechanic?
This what Volvo gives for those codes.
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Circuit Range/Performance
This is the same issues as you have i would start by reading this https://volvoforums.com/forum/volvo-s60-v60-10/scanner-p0235-p0236-35084/
Cost about $90.00 http://www.fcpgroton.com/product-exe...282001-2002%29
