Scanner P0235/P0236
Old Oct 5, 2009 | 01:16 PM
orig_nautique's Avatar
Default Scanner P0235/P0236
I have a 2002 S60 2.4T w 105k (haven't replaced timing belt etc.... yet).
My car started acting up and had trouble starting (check engine light came on). It idle rough for a while and giving a little gas also seemed like it was misfiring.
I used a generic ODBII scanner and it read the following: P0236/P0235. Could this be the issue starting the vehicle? I cleared the code, and it ran fine for a while, but it finally came back and started having issues again when starting.
I thought my trouble would be the throttle body being dirty (have not looked at it).
Any suggestions (Based on a similar thread it suggests the MAP sensor)?
Thanks in advance......
Old Oct 5, 2009 | 01:34 PM
blackbrick's Avatar
by search found this
P0235 - Turbocharger Boost Sensor 1 Circuit
P0236 - Turbocharger Boost Sensor 1 Performance P0236 The PCM has determined that the input voltage for boost pressure sensor "A" is out of range for the current engine operating conditions. Boost Pressure Sensor Issue
Old Oct 5, 2009 | 02:36 PM
Thanks blackbrick,
Could that cause start up issues based on the turbo sensor?
Old Oct 6, 2009 | 01:09 AM
blackbrick's Avatar
I believe so but I am not expert. Wait for experts opinion.
Also do that timing belt ASAP
Old Oct 8, 2009 | 08:22 AM
Bender's Avatar
MAP sensor - its on the charged air pipe coming out of the intercooler (right behind it actually) open your hood and it will stare you in the face!
90 dollars or so at the dealer and literally a 90 second swap out.
Chart
Oct 11, 2019 01:03 PM
nyc1836
Apr 7, 2014 10:25 AM
peterz
Oct 23, 2010 05:47 PM
walter351_
Aug 26, 2009 11:07 PM
sjonnie
Jun 11, 2009 10:57 AM
