Check Engine Light with NO codes?
I have a 2001 2.4t and my check engine light has been on for a couple of days (Work schedule prevented me from checking earlier) and the local autoparts store connected the OBDII reader and found NO codes. Any ideas of what this could be? I adjusted the gas cap just in case, even though it wasn't showing any evap codes.
Would the dealer be able to read any codes that were "not available" to a general code reader? I am planning on disconnecting the battery to see if it will reset but I hate to do it if will erase any code that might be stored....
Any suggestions?
Thanks!
Any suggestions?
Thanks!
RE: Check Engine Light with NO codes?
ORIGINAL: NCS60
Any suggestions?
Thanks!
Any suggestions?
Thanks!
Then took it to a Indy Volvo mechanic and he found the code, and it was the MAF disconnected (my bad from changing plugs).
the OBDII reader won't pick up most Volvo codes for some reason. He picked it up right away.
It's emission control related probably, O2 sensor, MAF, bad plug, something like that. Not major but needs to be addressed.
Thanks! I just replaced my MAF sensor about 2 weeks ago, so HOPEFULLY it isn't bad already! I was assuming it was probably an 02 sensor or possibly a bad plug. My car seems to be running good and my gas mileage has even increased after replacing my MAF. Unfortunately I still have the crazy idle problems that the dealer duplicated but stated it wasn't bad enough to know for sure at this point???
Anyway, I will try another reader on it first and I will take it to the dealer[]
Thanks for the Help!
Clean your throttle body. I am not sure of the terminology and it may not apply, but usually the idle is controlled by an Idle air contol module or motor. Usually is attached or just off the Throttle Body. In Fords it's called an IAC. When idles fluctuate most times it's the IAC or a dirty throttle body butterfly valve opening. This is probably not it, but change the airfilter as well. Keep eliminating the cheapest things first.
Possibly the code will tell you what it is.
I replaced the air filter at the same time as the MAF (2 weeks ago). The throttle body probably needs to be cleaned but I honestly have never tackled this on a Volvo and I was under the impression it was a fairly difficult task on a P2 TB. I have cleaned TB's before but I am a little confused on what to take apart to get to it? Any suggestions.....
Either way, I am going to have the code read at the dealer.
Thanks!
Thanks!
Dealer looked at it yesterday and found a code for the ETC Sensor/Thermostat ECM #201A and also found a faulty climate control fan motor sensor sensor CCM #0003 (obviously this one isn't related to the engine). They also gladly told me my rear brakes are about gone (which I already new). Also, they stated I need to replace the thermostat and coolant at the same time as well. Needless to say, I haven't had it repaired and it will be parked over the holidays until I figure out whether I will continue to dump money into it or trade it at this point. It is starting to add up at this point.
Thanks everyone for the help.
I cleaned my MAF and idle control valve shortly after I bought my 960 with PB Blaster and then MAF cleaner because of rough idle problems. It worked great and I repeat it about every other oil change and it runs like A top (now if I could ever figure out this tranny code I would be set).
ErnstlS90
10-23-2008 08:37 AM
gabyman97596
05-14-2007 09:52 PM
