Clicking under dash
Clicking under dash
Hi everyone,
I'm having a bit of an issue with my 04 S60 2.5T AWD. There is a clicking noise coming from under the dash. It usually happens when the blower fan is turned off, when braking, and when the windshield washer spray is turned on. I'm not sure what those would have to do with eachother, if anything. If anyone could shed some light on this I'd appreciate it.
Thanks
Thanks
Coincidentally there is a thread with the same topic and same author over at swedespeed!
Check this out ...
http://forums.swedespeed.com/zerothread?id=113532
Check this out ...
update:
I brought the car to the dealer. The tech said that the noise was the damper motor and that it was normal, but I'm still not convinced. It seems to be the same issue that some S40's have with the "barking" ECC which is fixed by a software upgrade. Does the same problem apply to the S60?
But on a lighter note, the tech at the dealership was really good about fixing the sunroof (needed lubrication) and removing the very annoying parking ticket holder.
