Clunk / Pop going from park to reverse; o6R w/ auto transmission
Old Jun 26, 2010 | 07:02 PM
mcaanda's Avatar
Question Clunk / Pop going from park to reverse; o6R w/ auto transmission
Wife came in today saying that the R was in the garage and when she went from park to reverse, there was a "clunk" and then the car hesitated a bit before it started to roll backwards.
I've noticed that there's a clunk sound on it when going from a parked position to drive as well as reverse. This is the only time that it makes any noise, which eliminates the CV's...
Thoughts? I've hit up the search which leads me to wonder about the "axle ping" but this seems to only be while in motion where as this only makes noise when the car has been sitting and is being put into motion.
Thoughts?
Car Info:
o6 S6oR, auto trans, and about 57k on the clock.
Old Jun 26, 2010 | 09:48 PM
volvofag's Avatar
Default Hi
The way you describe the problem: “when she went from park to reverse, there was a "clunk" and then the car hesitated a bit before it started to roll backwards” it looks like the car has a transmission problem. The “clunk” noise can come from different parts of powertrain, mounts, subframe, suspension etc, but hesitation is related with the transmission control system operation, I think. It is an internal fluid leak, a faulty solenoid or a mechanical part this is hard to say without running few diagnostic procedures. Better consult a transmission shop.
Old Jun 28, 2010 | 07:00 AM
RPMCanes's Avatar
You might want to check the motor mounts too.
Jan 17, 2014 08:57 PM
hnikole123
Sep 17, 2013 03:06 PM
tv23
Feb 24, 2011 08:23 AM
bbernard
Aug 25, 2010 06:44 PM
burkem
Sep 29, 2005 02:47 PM
