Clutch won't shift in reverse.
Is there something preventing the clutch pedal from touching the floor? (a bunched up floormat)
If not you may have a hydraulic problem with the clutch release mechanism - sorry but the slave cylinder is inside the bell housing on your car - or you could have a clutch plate that's about to come apart. Both require $$$ to remove the transmission.
As a work around, put the trans in a forward gear (to stop the trans from spinning) immediately before trying to put in reverse. Do not raise the engine speed during this process, it will only make it worse.
If reverse is grinding and the forward gears do not - The clutch is not releasing all the way - that means the transmission is still spinning slightly with the clutch pedal all the way in. The forward gears are synchronized - there is a "brake band" or synchronizer on each gear to synchronize the speed of the gears so they don't grind. Reverse has no "brake band" so therefore is not synchronized - and will grind if the transmission is still spinning when trying to engage reverse.
OK your clutch is not releasing completely - As a work around put the car in reverse before starting the engine it to keep it from grinding.
The solution IF your hydraulic system is working properly - is a new clutch.
Don't be pissed - Automatic transmissions have more expensive problems than clutches! There's thousands of Volvo Automatic transmissions that have needed to be replaced to the tune of ~$5000 with less than 97k miles!
You said new clutch @97k miles, then sat for years - how often has the brake fluid/clutch fluid been changed? Every 2 years as recommended?
