Coolant Temperature gauge broken?
I promise this is my last thread,
My engine temperature gage is being kinda wacky, I noticed that it never stays consistant. If I drive on the freeway, it drops to low, when I get off, it'll raise a tad bit, but it may go right back down. When its near half, the heat will work, but when it drops low, the heat will only blow cold air.
Is it a sensor or the water pump failing? This is my first Volvo and I really like it but Im thinking if its gonna give me issues I want to sell it, my mechanic told me if I find the exact issue he can fix it.
The fact that you lose cabin heat when the gage says the temp is low and have it when the gage is high would make me think your gage is working. Is there any chance you are low on coolant? the smell would make me think you have a leak. Is your system holding pressure? faulty fan operation and or thermostat as mentioned would be worth checking into. I have found thatmy temp comes up pretty quick and has very little variation while running....
If the thermostat is open it should be possible to see movement of the coolant in the surge tank.
J. H. McCharen
05-26-2014 11:26 AM
