Fuel Pump whistle solution?
Old Feb 16, 2011 | 09:25 AM
volvovera's Avatar
Default Fuel Pump whistle solution?
A few days ago I have posted a thread about the high pitch noise at the rear end.
Now I track down the whistle coming from the fuel pump.
Usually the noise starts whenever I start the engine. So this time I started the engine, the noise just stopped as soon as I pulled out the fuel pump fuse (fuse 33). The Car is 04 T5
Now I am considering the causes to this high pitch whine.
1. whether a clogged fuel filter can cause a noisy fuel pump?
2. whether a fuel pressure regulator problem can cause fuel pump whining?
3. bad fuel pump?
May some one give me some suggestion?
Thanks a lot in advance!
Old Feb 16, 2011 | 12:56 PM
J. A. Higgins's Avatar
It could be a leaking fuel regulator check valve.
Old Feb 16, 2011 | 02:11 PM
titaniums6025t's Avatar
It is extremely common for a fuel pump to whine on it's way south- in other words, put a pump in it before it leaves you sit!
spidersilva
Aug 17, 2011 07:23 PM
playa7970
Sep 23, 2008 11:50 PM
Moon
Oct 22, 2007 08:56 PM
xpiecemealx
Mar 31, 2006 10:43 PM
