Couple S60 issues
Old Apr 7, 2010 | 10:12 PM
jsabin's Avatar
Default Couple S60 issues
Hey I bought a 2006 S60 about 4 months back and it recently has started to have a couple minor issues that are annoying.
First is the drivers side window, when I lift up all the way to get it to automatically close it gets to the top then goes back down on its own. To me this seems like it would be some sort of adjustment problem, but I am not sure... any insight??
Second, the the passenger side rear door when either locking or unlocking it makes a grinding type noise, almost like there is a belt trying to run across a sprocket and it is just slipping. Is this a difficult issue to fix and does anyone know any steps to do so.
Thanks a lot
Jeremy
Old Apr 25, 2010 | 01:46 PM
Sarcastic1's Avatar
Your first problem is an issue with the computer. If you take it to the dealer, they can change the code and you'll be out in 5 minutes.
I had the same problem after having my window fixed at my local mechanic because he didn't have the proper program to reset it. While you're there, it probably wouldn't hurt to have the boys in blue take a look at your seat belts. Volvo for life isn't applicable if you're going to fly out of your seat!
Old May 1, 2010 | 10:41 PM
SVTfocusO3's Avatar
your second problem is more than likely a bad lock mechanism.
guy_014
Jun 17, 2009 10:14 PM
tr_car_nut
Nov 16, 2008 12:19 AM
Tupolev22m
Sep 12, 2006 02:27 AM
crossworx
Oct 8, 2005 04:46 PM
