Which direction do the CAMs turn on S60
Old Jun 23, 2012 | 04:05 PM
DeanH's Avatar
Default Which direction does the timing belt rotate on S60
I just replaced the timing belt on my 2002 S60, the directions say to that after replacing the belt, to adjust the tensioner and then turn the crankshaft 2 full rotations in the normal direction. I forgot to check the direction before I removed the belt, but I'm assuming the direction is clockwise. Can someone please confirm the direction the timing belt turns when viewing the engine from passengers side looking at the timing belt.
DeanH
Jun 23, 2012 10:29 PM
Chris092183
Feb 11, 2011 12:03 PM
bigdaddyrdpjr
Oct 13, 2007 09:47 PM
Branan
Dec 8, 2005 09:15 PM
Colin Carter
Oct 3, 2005 10:09 PM
