Drive Shaft Bearing?
Old Sep 5, 2010 | 03:03 PM
Inspector's Avatar
Default Drive Shaft Bearing?
Hi All
Just to introduce myself
I recently took the plunge and bought a 2004 S60 D5 SE - Really impressed and a great car - It is high mileage (138000) but seems to drive like new except for this below...............
I have already got some great tips from this site and am trying to sort out an annoying noise that seems to be coming from the O/S front - It is like a whining noise / grumble and seems worst at 5-40 mph. When you have been driving for a while, and more after a motorway run, it seems to have a vibration / grinding noise that I can feel through the floor.
I changed the wheel bearing and guess what - the bl***y noise is still there, although somehow the car 'feels' smoother
Anyway I took the engine cover off underneath, and put a long thin screwdriver on the bearing carrier for the drive shaft. When I spin the wheel I can hear a clicking noise from the carrier bearing. I put the screwdriver on the gearbox where the driveshaft goes in and there is no noise, so I am guessing the carrier bearing is worn out?
I suppose I will have to change the driveshaft and hope for the best - but are these a fairly common item to wear or am I just unlucky?
I would appriciate any thoughts and any advice and any locations I can source a driveshaft or bearing from
Thanks
Old Sep 6, 2010 | 09:20 PM
Delirious's Avatar
Default Welcome to the forum!
At 138k miles you may as well replace the drive shaft as you will need to replace the outer boot in the near future. I changed both of my drive shafts at 90k miles with rebuilt units for $140 a piece as the boots were torn and the right one (as it turned out) was giving the car an awful vibration.
Old Sep 7, 2010 | 09:16 AM
Manu Noypi's Avatar
At 90k miles, a torn cv boot and vibration caused by axle!!!!!!!!!!!!!!!!!!!! That's another classic example of Volvo poor quality parts.
Old Sep 29, 2010 | 09:18 PM
bobinyelm's Avatar
I just changed both axles on my '01 S60 T5 due to a vibration when turning right, and it's a NEW CAR.
Steering is now rock steady (hands-off, it would dart left/right with any road irregularity). No road noise now (or what I THOUGHT was road noise-must have been the right axle carrier bearing). The car rides better (harshness must have been CV joints not compressing/expanding freely with suspension compression).
The strange thing was BOTH axles "felt" fine off the car. No play in CV joints, no apparent binding or anything.
I couldn't find new axles locally, so I bought lifetime warranty remanufactured units from O'Reilly for $60/each w/ exchange. So far so good.
The entire job took me under 3 hours (the second side took only one hour since I had the procedure "down cold") w/ hand tools on jack stands.
I am one happy S60 owner again!
Bob
s60propshaft
Jan 15, 2023 06:59 PM
MoneypitC70
2001-2013 model year XC70
Oct 26, 2014 08:37 PM
Volvo-Profess
Jan 14, 2011 05:55 PM
lediii
Aug 4, 2010 09:35 AM
Kaybihiak
Dec 4, 2007 11:51 AM
