REPLACING CENTER DRIVE SHAFT BEARING
Old Dec 3, 2007 | 07:06 PM
Kaybihiak's Avatar
Default REPLACING CENTER DRIVE SHAFT BEARING
Does anyone have any advice on how to the replace center drive shaft bearing on my 92 240?
Old Dec 4, 2007 | 11:51 AM
billofdurham's Avatar
Default RE: REPLACING CENTER DRIVE SHAFT BEARING
It's true, we are divided by a common language. I assume you are talking about the shaft from the gearbox to the back axle, which we call a propellor shaft.
The shaft is in two parts and it is easier to remove them separately. First make some sort of mark on the universal joints and the flanges they fasten to, to ensure you get them back on as they were so they are not out of balance.
Remove the bolts from the rear universal joint/rear axle flange, lower the shaft and remove to the rear. The spline on the shaft will pull straight out.
Remove the bolts from the front UJ/gearbox flange but put a couple of bolts back in to take the weightwhilst you undo the two screws which fix thebearing housing to the chassis. Remove the front half of the shaft with the bearing housing attached.
Bend back the tab washer and unscrew the nut on the end of the shaft. Withdraw the bearing and its housing.
s60propshaft
Jan 15, 2023 06:59 PM
MoneypitC70
2001-2013 model year XC70
Oct 26, 2014 08:37 PM
fsmo
1998-2000 model year V70
Oct 1, 2014 11:34 PM
Volvo-Profess
Jan 14, 2011 05:55 PM
lediii
Aug 4, 2010 09:35 AM
