Driver door handle suddenly stopped opening the door from the outside...
Old Mar 5, 2021 | 08:33 AM
Ropsal46's Avatar
Default Driver door handle suddenly stopped opening the door from the outside...
I have a 2012 T6 R-Design S60, and as of 4 pm yesterday, my driver door handle stopped opening the door from the outside, and will only open the door from inside! So I have to go to the passenger door when getting in my car, open the driver door from the inside, then walk around and get in.
Is this a common issue to all of a sudden happen in my year and make? Also, what is the issue that needs to be fixed with the outside handle? And is it an easy fix I guess is my question.
Thanks in advance for any help you all can lend!!!
Old Mar 5, 2021 | 06:34 PM
ES6T's Avatar
Did you recently have your door lock recall performed?
Old Mar 6, 2021 | 10:51 PM
Ropsal46's Avatar
would that fix my outer door handle issue? What exactly does that fix? And no I haven't yet...
Old Mar 7, 2021 | 07:44 AM
ES6T's Avatar
The recall is to replace all four door latches. I askes because the outer handle is removed to do the recall, so maybe something broke during assembly.
The good news is if it hasn't been done, this can be repaired for no or very minimal labor while performing the recall.
Old Mar 15, 2021 | 09:13 AM
Ropsal46's Avatar
Having the Door Latch recall done tomorrow, so I'll keep you posted as to what the issue was.
Old Aug 3, 2024 | 10:43 PM
chezswan's Avatar
Question Update
Hello Ropsal46, having the exact same issue on the same model car… did the recall lock change fix the issue? Did they charge more?
thanks
Old Aug 3, 2024 | 10:57 PM
chezswan's Avatar
Question Update
thanks
karutunian
Mar 27, 2021 05:44 PM
James66666698
Sep 6, 2010 04:29 PM
yu21
Aug 1, 2008 11:37 PM
zerochills
Dec 27, 2007 01:53 PM
Layzie473
Jul 7, 2007 05:20 PM
