Electrical/computer problem
Old Apr 29, 2011 | 03:24 PM
lichtlmi's Avatar
Default Electrical/computer problem
This might sound selfish, but I hope someone else had this problem because nobody so far could help me.
This is the second time in seven years when it happened. There is a cracking noise (sounds like shorted wires) coming from the left side of the board (where the computer plug is) and the warning window goes crazy. I get left door open while driving, or air bags service, even brake failure. A couple of times, everything on the board went off.
Anything like this happened to anybody? Dealer says they cannot find anything wrong, unless they see it happen. By the time I went to the dealer, it didn't do it anymore. This is for a 2004 S60 2.5T
Thank you
Old Apr 29, 2011 | 06:45 PM
avguy's Avatar
Have you checked the grounds?
Old Apr 29, 2011 | 07:22 PM
jda2000's Avatar
Sounds like the DIM(instrument cluster) is beginning to fail. Apparently higher failure rate in '03 and '04.
Do a search on DIM failures.
Nathan Ashley
Sep 2, 2014 12:28 AM
pzvt
Feb 2, 2013 02:00 PM
louann
Mar 7, 2008 10:00 AM
S70driver
Feb 24, 2008 10:59 PM
lotusing
Oct 11, 2006 12:42 AM
