Engine Misfire troubleshooting Help
Its a 2002 S60T5. the car was running fine until the check engine started flashing and stayed on and the car is running hard and rough with these two codes
P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
P0305 Cylinder 5 Misfire Detected.
im going to dismount the cover to see the coils. and inspect coil 5, but to the first code
will it go away if i put a new coil if it is a coil problem??
divinedavis
02-28-2016 06:33 PM
badcircle
09-11-2011 07:28 PM
dcb
12-26-2010 10:24 AM
