Need some troubleshooting help
Old Apr 26, 2011 | 10:26 PM
Aftermidnight's Avatar
Default Need some troubleshooting help
On my 95 850 Turbo 160k pretty much all has been replaced. The issue I am having is on startup it runs loud at 3k rpms for about 30 seconds then goes to 1200 rpms. While driving it is at 1500 rpms and at a stoplight 800 rpms. Last week I had new NGK plug wires, new plugs and new distibutor cap installed hoping to fix the problem. Still no. No check engine light. Any idea what may be going on? Thanks.
Old Apr 27, 2011 | 02:35 AM
After the car warms up the idle is normal, 700-800 rpms?
Old Apr 27, 2011 | 05:43 AM
Yes it is.
Old Apr 27, 2011 | 07:05 AM
Henry10's Avatar
Aftermidnight: You said you "all was replaced" -- what does that mean in terms of Stage 0? You said no CEL: did you try to actually pull any codes? Rspi is alluding to your IAC (Idle Air Control Valve). I would add this as well How to Use and Interpret a Vacuum Gauge
Old Apr 27, 2011 | 05:47 PM
Sorry do not remember what stage 0 is?
Old Apr 27, 2011 | 09:33 PM
It is probably your idle control valve or your MAF. Next time you start it cold, take a screw driver and pop the idle control valve with the handle and see if it drops in line.
Old May 1, 2011 | 12:47 PM
Rosew6211's Avatar
Default RPM changes.
Lacking a code reader, you can check the Maf by disconnecting it electrically. This puts the motor in Limp Mode. If vehicle Idles OK in limp mode, you have MAF. problem. You can try some MAF cleaner spray; however, this did not fix mine. Got a new borch on e-bay. All works fine now.
Lansdowne
Sep 22, 2014 01:02 AM
badcircle
Sep 11, 2011 07:28 PM
Tyler 99 S70
May 17, 2011 12:33 PM
platinum_ghost
Oct 15, 2008 08:05 PM
B1mmer
Dec 18, 2006 11:24 PM
